laniadude Posted January 30, 2010 Report Share Posted January 30, 2010 I need a driveshaft for my 74 620. the carrier bearing is shot. Im looking for a one peice shaft but if you have a two peice with the carrier bearing in good shape Ill take it.... thanks Link to comment
datzenmike Posted January 30, 2010 Report Share Posted January 30, 2010 Are you sure it's not the rubber do-nut that's rotted out and causing the problem? Link to comment
laniadude Posted January 30, 2010 Author Report Share Posted January 30, 2010 Are you sure it's not the rubber do-nut that's rotted out and causing the problem? Thats exactly the problem but I dont know if they sell the rubber donut seperately... I thought the carrier bearing came as an assembly. I want to put a one peice driveline in eventually.... So i figured why not look while the truck is down.... Where can I get the rubber? Link to comment
datzenmike Posted January 31, 2010 Report Share Posted January 31, 2010 I don't think it's available anymore. It's now made of unobtanium. I used a 1" strip of rubber conveyor belt belt wound around the outer bearing surface. Wound it around enough times to build it up so it would clamp down and hold in place and trimmed to suit. It worked so well I stopped looking for a replacement for it. Cost zero for the rubber. . Link to comment
ggzilla Posted January 31, 2010 Report Share Posted January 31, 2010 Sure the driveshaft bearing is available new. $146.58 Nissan Also you can get Timken and other brands. Link to comment
