bac Posted January 24, 2010 Report Share Posted January 24, 2010 On 74 pl620 pick-up, will there be any problem switching from 14" stock rims to 15" chevy type rims. Mostly concerned re: handling. Thanks, y'all. Bac Quote Link to comment
datzenmike Posted January 24, 2010 Report Share Posted January 24, 2010 I've got 15" on mine. You could get a tire size that is almost exactly the same in 15" rim. Well, adjusted for width and height. The stock tires were nylon so just switching to a radial will improve the handling. Stock tires are 6.00 X 14 which is close to 175/70R 14. If the chevy rims are wider you can keep the same tire height/diameter and just adjust for width. For example a 180/60R 15 would be identical but 7" wide, a 205/55R 15 would be 8" wide and so on... Quote Link to comment
