loveoldrice Posted January 17, 2010 Report Share Posted January 17, 2010 i hate the bumpers on my 74 260z ... what can i do ?? 240 bumpers ?? Ive heard VW bug bumpers ?? Open for input ... Thanks Quote Link to comment
Skib Posted January 18, 2010 Report Share Posted January 18, 2010 i hate the bumpers on my 74 260z ... what can i do ?? 240 bumpers ?? Ive heard VW bug bumpers ?? Open for input ... Thanks 240z stockers or 240z FG bumpers from MSA Z's arnt rice btw ;) Quote Link to comment
greybeard Posted January 18, 2010 Report Share Posted January 18, 2010 240Z bumpers , but don't forget the early valance or it won't look right forget about the bug bumpers, it would look like......... a Z with a bug bumper tacked on :poke: Quote Link to comment
loveoldrice Posted January 18, 2010 Author Report Share Posted January 18, 2010 are bracketry direct bolt ons ?? Obviously mine has the impact tube brackets .... Quote Link to comment
Skib Posted January 18, 2010 Report Share Posted January 18, 2010 are bracketry direct bolt ons ?? Obviously mine has the impact tube brackets .... nope, you need some 240z to late 260z/280z brackets Quote Link to comment
DatsunMotorSports Posted February 6, 2010 Report Share Posted February 6, 2010 Do you have early or late 260Z bumpers? IF you have early you are in luck. Your bumpers will tuck back up against the body with very little effort. There are 4 shock absorber devices that attach the bumper to the body. IF you dont mind loosing these 5MPH cash safety devices here is something you can do to get a more aesthetic look. Each of the shocks is filled with Nitrogen. They are charged like a gas shock. IF you pull these shocks of you will find a small phillips screw on the shock tube itself behind the bumper mount. CAUTION!! HIGH PRESSURE GAS!!! remove the screw from the shock carefully. USE COMMON sense and safety. Once the gas is removed re-install shocks. Attach your bumper again. Firmly push the bumper against body. It will stay in place for the most part if thats all you do. I drove 15K miles like this. I suggest once you have the bumper in the place you want it to mark it and take the shocks back out. Take them back out and weld the 2 shock halfs together where you marked it. NOTE: all the ugly rubber stuff that goes behind the bumpers will be removed in this process, though I kept the center front rubber and slid it into the grill to help air flow around the bumper. This should achieve your goals Ray Quote Link to comment
DatsunMotorSports Posted February 6, 2010 Report Share Posted February 6, 2010 The Blue car is my 260Z and the white car is my 71 240Z Quote Link to comment
