BlakeZula Posted January 15, 2010 Report Share Posted January 15, 2010 so... the PO has a bunch of bolts into lines example: so theres that one.. and one behind the carb. and theres a big metal hose... wich i have no clue goes to what.. but there is a fitting on the back of the airbox. pic of the hose: basically my question is... is this bad? if so... what do i do? im not sure where they go. Quote Link to comment
datsunaholic Posted January 15, 2010 Report Share Posted January 15, 2010 The big metal tube is supposed to have a hose connected to it going to the PCV. The plugged vacuum line used to go to either the EGR valve or the vacuum line on the charcoal canister. The one behind the carb probably went to the anti-backfire valve but it's hard to know without seeing it. Quote Link to comment
Skib Posted January 15, 2010 Report Share Posted January 15, 2010 go to the parts store and get some proper vacuum caps and hook that PVC up Quote Link to comment
BlakeZula Posted January 15, 2010 Author Report Share Posted January 15, 2010 go to the parts store and get some proper vacuum caps and hook that PVC up that goes to the back of the air box? Quote Link to comment
