spanky Posted January 9, 2010 Report Share Posted January 9, 2010 i have a rayjay set up that fits a l16 and l18 , 19 to it uses the factory carb or weber blown through the turbo does any one els have one my turbo is apart and has broken parts i would like to find a turbo to fit it so i can put it on my 510 goon Quote Link to comment
datzenmike Posted January 9, 2010 Report Share Posted January 9, 2010 If the turbo pulls/sucks air and fuel from the carb and blows it into the motor it's known as a draw through set up. (likely what you have) If the turbo pushes air through the carb and into the motor then this is known as a blow through set up. Someone should know for sure but the turbo may be a T-25? It's not that big nor is a big one necessary given the limitations of the Rayjay draw through set up. Quote Link to comment
