SubwayGUY4 Posted January 6, 2010 Report Share Posted January 6, 2010 So I got a subi diff and it ended up not being lsd. well so far I only have two issues the front and the drive shaft don't line up. I suppose I'll just use the 510 one but I can't stop it from spinning any ideas? Second, the axle stubs that go into the diff can just slide out far enough to where the wheel wont spin. I tried to put in the bolt that was suppose to go there but there wasn't anywhere for the bolt to go into. Quote Link to comment
DISLEXICDIME Posted January 6, 2010 Report Share Posted January 6, 2010 So I got a subi diff and it ended up not being lsd. well so far I only have two issues the front and the drive shaft don't line up. I suppose I'll just use the 510 one but I can't stop it from spinning any ideas? Second, the axle stubs that go into the diff can just slide out far enough to where the wheel wont spin. I tried to put in the bolt that was suppose to go there but there wasn't anywhere for the bolt to go into. spond like you git the wrong dif what year is it from Quote Link to comment
SubwayGUY4 Posted January 6, 2010 Author Report Share Posted January 6, 2010 well quite frankly i have no idea dude told me 2000 2.5rs that has to be a lie since it would be LSD then yeah....... are are the stubs supposed to lock with a bolt of some sort just like the 510s? cause there is a bolt that is supposed to hold them in but the subi one didnt have that Quote Link to comment
SubwayGUY4 Posted January 6, 2010 Author Report Share Posted January 6, 2010 or better yet am i supposed to be using the subi axles/maybe my stub axles need to have a C retainer clip on them? Quote Link to comment
DISLEXICDIME Posted January 6, 2010 Report Share Posted January 6, 2010 most guys use the 92 and older subaru dif Quote Link to comment
BJW's FiveTen's Posted January 6, 2010 Report Share Posted January 6, 2010 The viscus Subaru diffs look like an open diff. The passenger side stub axle is double splined and longer than the drivers side axle.These axles are held in by a clip in the splines like a FWD car. There is a write-up on DQ,on how to make it work in a 510, Sorry. I bought the issue with info on doing it, has some good info. So don't give up hope yet. Thanks Bryce Quote Link to comment
SubwayGUY4 Posted January 6, 2010 Author Report Share Posted January 6, 2010 i figured they had C retainers..... now the only problem is how am i going to get that to work? and i dont think it is lsd? but you are right about the passenger side being a bit longer. but when i cracked it open it looked like the same old r160 where i could see the spider Quote Link to comment
BJW's FiveTen's Posted January 6, 2010 Report Share Posted January 6, 2010 i figured they had C retainers..... now the only problem is how am i going to get that to work? and i dont think it is lsd? but you are right about the passenger side being a bit longer. but when i cracked it open it looked like the same old r160 where i could see the spider Like I said it looks open, spider gears and all. And It can be made to work. There Is a Dime Quarterly Article that covers all the things needed to install a viscus subie diff. What did the tag on the cover say. My Subie VLSD said right on the cover 3.90 VLSD, my clutch type said 3.70 LSD. And You can spin all the parts in a viscus diff by hand if you don't have the proper axles in it. Do your homework, can you get the vin off the subie and check with subie and see if a VLSD was offerd in that model that year. My Vlsd came out of a legacy, who knew. I did I did my research. Thanks Bryce Quote Link to comment
