kezark31 Posted December 22, 2009 Report Share Posted December 22, 2009 anyone used a gm 4 pin modual with this dizzy? i know you can with the old l series if you dont have the match box. this one has that modual built in and im running an aftmarket system that requires and magnetic pick up similar to mega squirt. Quote Link to comment
bigjoe619 Posted December 22, 2009 Report Share Posted December 22, 2009 i had a nap z in my 510 and i didnt run the modual , what color wires do you have commin off the dist? Quote Link to comment
kezark31 Posted December 23, 2009 Author Report Share Posted December 23, 2009 there is 4 wires im pretty sure im going to have to tear the modual a part and seperate the pick up from the ignitor. the is black with a white stripe, brown, blue with white strip, and red. i tracked down another dizzy from a 4 plug z20 that i might use. Quote Link to comment
datzenmike Posted December 23, 2009 Report Share Posted December 23, 2009 (edited) Pretty sure the pick up and igniter are combined in one. Here is a 3 terminal Z22 dizzy igniter http://i138.photobucket.com/albums/q251/datzenmike/Nissan%20Electrical/720distributor005Large.jpg[/img]"] http://i138.photobucket.com/albums/q251/datzenmike/Nissan%20Electrical/720distributor010Large-1.jpg[/img]"] In the picture above: the shiny C shaped thing near the top with the screws is the stator.(the bottom black half of it is the magnet) The black star wheel thing in the middle below the stator/magnet is the reluctor. Below it, the black thing with a hole in it and three terminals is the igniter. When the reluctor aligns with the two stator terminals the magnetic field is transmitted to the coil built into the round hole in the igniter. The magnetic pulse is used to turn off the flow of power to the coils to fire them. If you have 4 terminals on the igniter, then you have a dizzy capable of shutting the exhaust plugs off via a manifold vacuum switch. Only the Z24s in Canada got this. I don't think the Z22s got this and have never found out if the States did or not. kezark31 are you in the States or Canada? Brian, that reluctor looks exactly like the L dizzy one I sent you. Edited December 23, 2009 by datzenmike Quote Link to comment
kezark31 Posted December 24, 2009 Author Report Share Posted December 24, 2009 thats the beast! im in oregon. yeah im going to come up with sumthing. thanks for the help Quote Link to comment
