FS/Trade Projects w/Me - 74 620 + Tons of Parts (FJ20, RB, etc.)
Located in Bedford, VA. I have a problem with starting too many projects at the same time. I had wanted to do something fun with this 1974 620, but I really should finish one project at a time. The truck is a great piece to start with - NO Rust. OK, there is some surface rust forming on the frames, but no rot in any panels or on the frame. Overall, a great platform. It's an auto with a siezed engine, clear title, straight frame and body.
I have also collected alot of parts over the years - any one of these engines would make a killer project. Head over to the photobucket link and look at the pictures. I have:
L20B complete
VH45DE complete with auto and ecu
RB20DET complete with awd trans and ecu
FJ20ET with custom equal length top mount mani, trans, and few other upgrades
1UZFE complete engine
Several VG30DE's in various states
SDS v.3 standalone engine management system (fuel and spark)
I also have a rusty Celica RA21 (trunk version)
So, if any of these vehicles, or combinations of vehicles+parts+engines sounds interesting, let me know. If you have a project that you'd like to trade, I'll listen too (no more datsun trucks, please). I'm really interested in an FJ Land Cruiser (60 or 80) if I can find one.
http://s434.photobucket.com/albums/qq66/heinekenns/Project%20Parts/
  • Replies 10
7-4, I will get pictures later this week if you are interested. Did I mention it is rusty? It has a 20R and will start and drive. A 1UZ would be fun in that car - now who has one of those engines for sale?
Skib, It is an EM-3 F. I have two eeproms for it. One is for a 4cyl with a 3.5bar map sensor and the other is a 6cyl with a GM 3bar map sensor. It has a 3 coil setup for up to 6 cyl. I used it first on an RB26, and then on my FJ20. I'll include both eeproms (4 and 6 cyl), map sensors (AEM 3.5bar, GM 3 bar), idle air control valve, LCD programmer, Air temp sensor, Water temp sensor, main wiring harness, Injector harness, Fuel trim control, +, - 50%, Crank sensor, and
Coil/amp unit for 750 + shipping.
RadioRedline, The RB20 needs a new crank timing-belt cog. I took the front cover off to replace the oil pump and this had to be cut off since it seized to the snout. The oil pan is the same as the RB26 AWD, and I have already cut the differential off and cleaned it up for use RWD. I'll include the motor, trans, wiring harness, ecu, and all the parts it came with for 900 + shipping.
Motivated, I'd like to get 700 for the datsun. It is a really good start for a project. The truck is straight and clean. PM me with more questions about the FJ - like what transmission, parts, etc.
  • 1 month later...
