amp 4 a 620 only!
  • Replies 2
output, channels, current draw? if its a 500 watt amp or bigger it will draw 50+ amps from your charging system, not so good for a 35 amp alternator, but definitely cool that it is a "620 amp" lol, i have yet to see a cool system in a truck so small!!! i was just gonna run a 400/4 in my truck with 2 6x9 and 2 6's in the kick panels, what did you have in mind for your truck?
well right now i have 2 4inchers by my door panels, a 750watt amp and a 10 inch sub bridged in a ported box everything lightning audio with lightning audio wires. it aint too bad. it sounds really good because everything is perfectly made for eachother..... 750watt amp and a 750watt sub in a box made perfectly for the sub. hits as hard as alot of 12's. i can do better tho its just temporary
