P brake cable long bed 620
  • Replies 4
the rear driveshaft is the same length so I would think the rear section of cables are the same on short beds and long beds.
It would likely just be the single cable going from the fork forward to the cab that is longer. In that case (if you need that part) the Kingcab or longbed truck would work as a parts donor.
Hmm, I was thinking that might be the case for a while, but when I asked at carquest to see if they could order it, a supplier had separate cables for long and short beds. That's why I assumed they were different lengths, but a king cab might work... Does anybody know if the king cabs and long beds have the same fender to bumper length?
I'll check it out at a yard, thanks for the idea Bleach.
