Danfinny Posted November 21, 2009 Report Share Posted November 21, 2009 OK guys i am trying to hook up an AFC Neo to my OBDII KA powered 510. so i can have a Tach. the problem is that i am not getting a signal from the ECU. anyone got any Ideas. Quote Link to comment
72240z Posted November 21, 2009 Report Share Posted November 21, 2009 Did you test the pin? Quote Link to comment
Danfinny Posted November 21, 2009 Author Report Share Posted November 21, 2009 I did and got nothing from the wire. it is Pin 3 on the ecu according to the ecu pinout. other problems to i think because i cant get a throttle signal either. the sensor reads out fine though. ahhhh i hate wiring Quote Link to comment
72240z Posted November 21, 2009 Report Share Posted November 21, 2009 If you capable I would check back through the board but if not and even if so the easiest way would be to get a ecu you know is good and check it out. ka ecus aren't expensive or hard to come by Quote Link to comment
Danfinny Posted November 21, 2009 Author Report Share Posted November 21, 2009 OBD II ones are at least at the junk yard lol. Quote Link to comment
72240z Posted November 21, 2009 Report Share Posted November 21, 2009 I keep forgetting the coast difference, ka's are way more cheaper/plentiful here. Still vote you check another ecu, even if it's just a buddies or w/e, takes 5 min to plug it in and know 100% where the prob lies. Quote Link to comment
WagDatto Posted November 21, 2009 Report Share Posted November 21, 2009 Look on Zilvia.net. They've had so many partouts in the past few months it's retarded. It's an OBD II so it's 96-98, obviously. Shouldn't be hard to find something for $50 or less. Is it a 1995? If so, it's wired slightly different than the other OBD I's and isn't a real OBD II either... pain in my ass. Quote Link to comment
