Ridge Racer Posted October 24, 2007 Report Share Posted October 24, 2007 Would I have to weld new engine mounts? What all would have to be done to get the engine from my '92 240sx in a '79 620? Quote Link to comment
BEEBANI Posted October 24, 2007 Report Share Posted October 24, 2007 I just modified the original mounts that were on my ka to match the rubber part that's mounted to the 620 frame. If your motor is a front sump like mine; you have to modify the steering link to fit around the oil pan. Are you going to use the 240 tranny? If so, you'll have to modify the x-member and I think the driveshaft? (help guys) and you'll have to modify the wiring, which is pretty straightfoward. Quote Link to comment
Bleach Posted October 24, 2007 Report Share Posted October 24, 2007 Read through this http://forum.ratsun.net/showthread.php?t=40 This goes through the install of a Hardbody KA24e rear sump into a 620. Icehouse talks about the differences between that engine and the car (240SX) KA. Most of the swap info is relavant to what you're asking about. Quote Link to comment
