Guest Rick-rat Posted November 16, 2009 Report Share Posted November 16, 2009 I finished my drum brake replacement on my 620 and was having a great deal of difficulty adjusting the rear drums. after much frustration I decided to remove my lowering blocks one side at a time and by doing this adjusters were below the leafs and shock mounts out of the way. very good access to the wheels and adjustment was a snap. Yes I did put the lowering blocks back in when I was done. when they need to be adjusted again I will do it this way Quote Link to comment
banzai510(hainz) Posted November 16, 2009 Report Share Posted November 16, 2009 Rick I have this same proplem. I have a tool that make sit abit EZer to adust the wheel but is a pain with lowered blocks in the way. Sometimes it might be Ezer to pull the drum off(if jacking threads were installed on the drums) and adjust the wheel from the front an put the drum back on. Quote Link to comment
