Dat620 77' Posted October 23, 2009 Report Share Posted October 23, 2009 turn signals: replaced flashers switch and all fuses work my hazards got them working once in awhile should say they got a mind of there own.not to worried now turn signal can get nothing same with wipers i know im getting power need help plz help me Quote Link to comment
datzenmike Posted October 23, 2009 Report Share Posted October 23, 2009 If the hazard light only work some of the time then it's likely the switch. In order for them to work the turn signals are disconnected internally. When the switch is turned off the turn signals are supposed to be re-connected back up. Take the switch apart or replace it. Try on/off/on/off/on/off to rub the contacts up and clean them. The 720s are bad for this. Try turning the switch to OFF and then move it just slightly toward ON and try it. Quote Link to comment
