kaliboy96 Posted September 28, 2009 Report Share Posted September 28, 2009 Hey Guys I am in the middle of doing a BeeBani brake conversion on my 69' 521 Turbo! I have purchased all of the necessary parts such as The new 280z M/C, the Isuzu Rotors, 1990 Hardbody Calipers, new soft brake hoses, and new metric hard lines (bought a kit on ebay for the 280z M/C it is a 10mm x 1.0 meter fitting that bolts right up to the M/C and Hardbody calipers saves a lot of time!) The problems I am running into are as follows, I bought a proportioning valve for the rear brakes but since I have not purchased the rear conversion I am still using the stock rear drums and lines! I want to install the proprtioning valve but cant figure out how to get the hard brake lines to fit 1/8" NPT fittings which are used for both inlet and outlet on the valve! Coming into the valve I have the new 3/16" hard lines with the Metric 10mm x 1.0, and coming out on the other side is the stock SAE 3/8" x 24. I have looked and have been unable to find adapters for either side. Can someone tell me how to install and where I might be able to find the adapters if they are needed. Also I have seen a few posts on the inner bearings but am not sure if this applies to me! Can someone tell meme the easiest way to remedy this problem. Thanks so much, I look forward to working with you all of you guys on this project! Quote Link to comment
mklotz70 Posted September 28, 2009 Report Share Posted September 28, 2009 I tried to respond to your pm, but your account isn't taking pm's. You need to send me an email address or turn on your pm's. Quote Link to comment
kaliboy96 Posted September 28, 2009 Author Report Share Posted September 28, 2009 Hey Mike my address is kaliboy96@yahoo.com. I have to figure out how to do the PM thing I will work on it right now! Quote Link to comment
