OneFreakyMF Posted September 26, 2009 Report Share Posted September 26, 2009 ok guys ... i consider myself to be a fairly mechanically inclined kinda guy but i could use some help. the two areas i am not so familiar with are transmissions and engine failures. so here it is .... my Z22 smokes heavily (blue smoke) when cold but as it warms up the smoking lessens to only a slight hint of blue, unless i rev the engine, then it smokes heavily again. all this started after it got hot on me once due to a radiator plugged with mud. promptly cleaned out the radiator and she runs nice and cool again. also there is a light "lifter tick" now .... i pulled the spark plugs and cylinder 1, 2, and 3 are fine but the fourth was "wet". looks more like fuel than oil. i did a compression test and these are the readings for four compression cycles per cylinder .... cylinder 1: 120, 120, 150, 180 cylinder 2: 120, 120, 150, 180 cylinder 3: 120, 120, 150, 180 cylinder 4: 120, 150, 150, 180 i checked for spark (by just hooking up a timing light to each wire) and cylinder 4 was kinda having some issues. bad connections .... and i probably need to replace the cap n rotor. gonna run into town tomorrow and pick them up. even after it looked like i was getting more of a consistant spark there is still the smoking issue .... oil and antifreeze look good too ..... any ideas guys??? thanks for readin!! Adrian Quote Link to comment
OneFreakyMF Posted October 8, 2009 Author Report Share Posted October 8, 2009 ok well .... replaced the valve stem seals .... adjusted valves .... new plugs, cap, n rotor .... ALL BETTER NOW!! YAY. Quote Link to comment
izzo Posted October 8, 2009 Report Share Posted October 8, 2009 wanna do mine? :D Quote Link to comment
OneFreakyMF Posted October 14, 2009 Author Report Share Posted October 14, 2009 not sure about the L20 .... but the Z24 should be pretty similar. was pretty easy. nylon rope, nice valve spring compressor, feeler gauges, new seals and valve cover gasket and you are set! i was a bit intimidated at first but had it done in a couple hours. Quote Link to comment
benzo Posted October 14, 2009 Report Share Posted October 14, 2009 nice work. was about to mention seals. you sound like the true backyard mechanic. Quote Link to comment
