butcherboyjc Posted September 4, 2009 Report Share Posted September 4, 2009 OK got her running, i have been through two sets of spark plugs already, running rich at idle and it wont start without starting fluid. i set the timing at 20 Quote Link to comment
Cuts metal like mad Posted September 4, 2009 Report Share Posted September 4, 2009 what sensors have you eliminated? Quote Link to comment
butcherboyjc Posted September 4, 2009 Author Report Share Posted September 4, 2009 All the sensors are plugged in I am running stock the only plug left dangling is the power steering pressure switch. Quote Link to comment
sycloned916 Posted September 5, 2009 Report Share Posted September 5, 2009 I would double check all the grounds, and put a filter on it and see what that does. Quote Link to comment
butcherboyjc Posted September 7, 2009 Author Report Share Posted September 7, 2009 Figured it out. The running rich problem was that I was suppose to eliminate, block off, the pcv valve. I forgot I was dealing with a maf not a map. Also I had another vacuum leak, which was the swirl control valve. The plastic nipple broke off during install, so im not running rich any more. As for my starting problem it was my ignition switch. The ignition(black & white) wire wasnt getting power during starting, but it had power on the "on" position so when i cranked and turned the key from start to "on" there would be power and sometimes the engine would catch enough spark for the engine to start. So i have to buy a new ignintion switch and re run my wires for my lights, horn and fan, and finish my exhaust. Quote Link to comment
