How to remove Pass. Door Glass
  • Replies 6
Anybody ever taken out the door glass ?
YES
Is it very hard?
NO
Any tips?
WHAT CAR?
Is it easy to take the whole door off?
YES
What procedure for the door?
HAVE A HELPER OR SUPPORT IT FROM ABOVE
if its the 510(read the haynes, etc manual)..., remove all the hardware and the panel.
not the sliding side but the other end has a clip (cotter pin style) facing the door, reach behind and remove it. pull the glass off of the pivot. slide the glass out of the chanel and remove. install is the reverse...
Guest 510kamikazifreak
As hang_510 said,
It is pretty simple,
To make it a bit easer pull the belt molding(chrome door molding)off ,to take the glass out,
Or a brick or rock will work too,Might not get the final result you are looking for tho:blink::lol:Re-Instillation this way may be a bit difficult,But if you are good with crazy glue might work:eek:
