1badsrd510 Posted June 4, 2009 Report Share Posted June 4, 2009 help me out I need before friday thanks Link to comment
sssr20det510 Posted June 4, 2009 Report Share Posted June 4, 2009 If your in a bind you can take the stock one flip it and push it up under the studes pinching it between the frame i ran mine like that for about 6 months no problem Link to comment
1badsrd510 Posted June 4, 2009 Author Report Share Posted June 4, 2009 problem is... it was welded to fit... but I snapped into two pieces when i tried to burn out two days ago If your in a bind you can take the stock one flip it and push it up under the studes pinching it between the frame i ran mine like that for about 6 months no problem Link to comment
xlr8r Posted June 4, 2009 Report Share Posted June 4, 2009 Just reweld it for now to get you by for the weekend. Just be sure to get it good and deep and maybe add another layer of flat stock to it to be safe. Then order up a purpose built bar from MadDat or what's his name up in the Bay Area (it's still early in the morning I can't remember the name of that shop, somebody help me out). I got mine through MadDat and they even custom made it per a couple measurements I gave them so I could use a Z32 diff cover instead of a Z31 cover. FYI, the mounting surface of Z32 covers doesn't stick out as far as Z31 covers making fitment easier. Link to comment
510Finn Posted June 5, 2009 Report Share Posted June 5, 2009 Just reweld it for now to get you by for the weekend. Just be sure to get it good and deep and maybe add another layer of flat stock to it to be safe.Then order up a purpose built bar from MadDat or what's his name up in the Bay Area (it's still early in the morning I can't remember the name of that shop, somebody help me out). I got mine through MadDat and they even custom made it per a couple measurements I gave them so I could use a Z32 diff cover instead of a Z31 cover. FYI, the mounting surface of Z32 covers doesn't stick out as far as Z31 covers making fitment easier. You mean either Troy Ermish of ermish-racing aka the 510 Parts Outlet or Dan of DGR Fabrication? Link to comment
