dat u racing Posted June 3, 2009 Report Share Posted June 3, 2009 will a 3rd member from a 2wd 620 fit in a 2wd 720 ? would like to run the 4.62 gear! Quote Link to comment
69FJWagon Posted June 3, 2009 Report Share Posted June 3, 2009 will a 3rd member from a 2wd 620 fit in a 2wd 720 ? would like to run the 4.62 gear! yes I have a hardbody 3:90 in my girlfriends 521 works great, I would verify the gear ratio I thought they came with 4:38s... Clayton Quote Link to comment
dat u racing Posted June 3, 2009 Author Report Share Posted June 3, 2009 thanks great news!!! the automatic's (620) came with the 4.62. my crew members are running trucks in the none points races and that gear will stomp the fords and yota's I'am sure it will be a lot of fun to pit for them!! Quote Link to comment
datzenmike Posted June 3, 2009 Report Share Posted June 3, 2009 Only the '74 automatic had the 4.624 ratio. The 520/521 with the J13 motor had 4.875 and aluminum carrier I believe. Quote Link to comment
datzenmike Posted June 4, 2009 Report Share Posted June 4, 2009 Be sure to check that the drive shaft bolt pattern works. Some 720s used a larger pattern, maybe just the 4X4s, not sure, but check. Yes, but only the Z24i motor Hardbody had the H-190 rear end. Quote Link to comment
dat u racing Posted June 4, 2009 Author Report Share Posted June 4, 2009 one year only , goinr to jy today. i know there is a auto, find out if it's a 74! thanks for the info. Quote Link to comment
bagged84 Posted June 10, 2009 Report Share Posted June 10, 2009 i tink i have a few alloy ones that are are ready welded up your running cicle track right i have many different ones Quote Link to comment
dat u racing Posted June 11, 2009 Author Report Share Posted June 11, 2009 let me know what ratio,s Quote Link to comment
