chebetio510 Posted May 6, 2009 Report Share Posted May 6, 2009 can i use a self adjusting slave cylinder on my dime. instaed of the adjusting one.. that would mean changing the clutch fork too.. would that be a problem?:confused: Quote Link to comment
banzai510(hainz) Posted May 6, 2009 Report Share Posted May 6, 2009 Those slaves are all the same. The self adjusting one uses a rod that fit on the fork that uses a cup. So when you bleed the clutch I guess it self adjusts. The old style you can adjust yourself. But the clutch fork has a hole where the threaded rod fits thru. You can use a so called self adj slave and just put the stock 510 threaded rod and ball on there. Quote Link to comment
chebetio510 Posted May 7, 2009 Author Report Share Posted May 7, 2009 i meant not using the threaded rod anymore.. using the regular one with no hole.. Quote Link to comment
banzai510(hainz) Posted May 7, 2009 Report Share Posted May 7, 2009 Im not getting what you want? Use the Rod that works with the Fork arm you have. You mention changing the fork arm to use the other ROD, Why even bother to do all that work dropping the trans. The Clylinders themselves are all the same up to the 240sx. Unless there is something majorly wrong here what you have should work UNLESS wrong T/O bearing and Or sleeve lenght Fork arm is bent/broke T/O bearing is jammed up inside. Sytem is not bleed correctly Quote Link to comment
chebetio510 Posted May 15, 2009 Author Report Share Posted May 15, 2009 if all slave cylinders are the same up to 240sx.. that means i can use one of a 720? Reason why is i believe my origonal fork is bent.. nad i plan on usin a fork i have for a 720,, Quote Link to comment
chebetio510 Posted May 17, 2009 Author Report Share Posted May 17, 2009 :mad: I HAVE NO FUCKEN PRESSURE!!!!!!! sorry. i finally got everything working right, no more play in fork, new ckutch, slave cylinder. hose and metal line.. it has no air in system but no pressure,.,, :mad: cant get it into gear.. and if i start the car in first gear. tires spin with clutch in Quote Link to comment
chebetio510 Posted May 18, 2009 Author Report Share Posted May 18, 2009 anyone??? Help/??? did the adjustment and nothing... Quote Link to comment
banzai510(hainz) Posted May 18, 2009 Report Share Posted May 18, 2009 (edited) Try a master is you havent already If you lived nearby i would help ya but nothing really else to the system. Master & slave thats it it should push unless something is jammed up. if you havent changed the master try that but I dont know what more else to tell ya Edited May 18, 2009 by banzai510(hainz) Quote Link to comment
chebetio510 Posted May 20, 2009 Author Report Share Posted May 20, 2009 so. got a friend over today... i believe to have figured out my problem.. the the carrier for the throw out bearing is too small for the og. clutch.. when pushing clutch all the way in.. it bearly reaches the pressure plate.. so technically not engaging.. never had a problem with the roadster cluch... but i guess the plates are different??? so now i have to get a thicker to bearing carrier... Quote Link to comment
