zed Posted April 21, 2009 Report Share Posted April 21, 2009 I'm assembling my L18 head - V912, now ported, with new valves, and skimmed .020 :cool: Is there a trick to pushing down the valve springs when fitting the rocker arms? The manual says to use a big screwdriver and lever against the camshaft - but I scratched one of the valve retainers with the screwdriver when I was stripping the head... gotta be a better way? thanks Quote Link to comment
banzai510(hainz) Posted April 21, 2009 Report Share Posted April 21, 2009 Isnt on the DVD I sent you? Like How I did mine. put the rocker on the vlave spring w/retainer lash pad then lever UP on the other side under the ball/cup end Lower the the Rocker arm Ball all the way downt he lever the rocker On with a screw driver or soemthing of that nature. Quote Link to comment
zed Posted April 22, 2009 Author Report Share Posted April 22, 2009 Got it done - thanks Hainz Quote Link to comment
