LAYEDOUTB2K Posted April 1, 2009 Report Share Posted April 1, 2009 this seems to come up every once in a while so i figured id post this up. i had to get a new fuel pump for my '64 320 and picked one up for a '66 520. in the pics you can see that the arm is a little different. where the actual contact point is on the arms are actually near perfect to each other besides a little different angle. when i mounted i made sure i felt that it didnt interfere with anything. i also used the hand crank to rotate the engine to make sure nothing unusual happened. i plumbed everything back up and it fired right up. so there you go, a direct bolt on replacement. Carter part # M70035 Quote Link to comment
Pacific coast Datsun Posted April 1, 2009 Report Share Posted April 1, 2009 Sweet so no arm mods needed? A direct bolt on swap for the 320's is good to know. I guess the J-13 & E-1's share a few parts. Quote Link to comment
LAYEDOUTB2K Posted June 15, 2009 Author Report Share Posted June 15, 2009 yeah it works with no mods needed. Quote Link to comment
