LCDC Posted March 13, 2009 Report Share Posted March 13, 2009 Hi its me, I'm back. I am eventually planning on converting my '77 king cab from drum brakes to disk brakes. Just wondering if anyone knew what all I need to change. Can I get away with putting the rotors on or do i have to change out the entire spindle or A arms? Your help would be greatly appreciated. Quote Link to comment
Guest DatsuNoob Posted March 13, 2009 Report Share Posted March 13, 2009 Tons of good info on this in past threads, you should find it fairly easy in a search, but yes the upper a arms will need to be changed so you can run D21spindles, ball joints, etc. Quote Link to comment
420n620 Posted March 13, 2009 Report Share Posted March 13, 2009 (edited) your in luck, so happens Datdoug is doing a swap to his 620. http://forum.ratsun.net/showthread.php?t=10359 opppsss,,, wrong year -- Oh well, you need to use the search option button.. Edited March 13, 2009 by 420n620 Quote Link to comment
