72 CnC_WaGon Posted March 9, 2009 Report Share Posted March 9, 2009 OK I NEED HELP WITH A CARB THAT I GOT ITS A WEBER AND THE NUMBER ON IS 32-34 DFT9 A. I PUT IT ON THE MANIFOLD AND IT WENT ON FINE. WOULD I NEED AN ADAPTER PLATE? THANKS FOR THE HELP. HERE R SOME PICS Quote Link to comment
littlekeeley Posted March 10, 2009 Report Share Posted March 10, 2009 maybe im missing something but... if it went on fine, why would you need an adapter plate? my weber is relatively the same and it just bolts right on. i think you will be fine unless im not mentioning something critical :rolleyes: Quote Link to comment
racerx Posted March 11, 2009 Report Share Posted March 11, 2009 I say take it for a spin. I think if it went on fine then you don't need an "Adapter" plate. And that's what it is to adapt a particular part to another to make it interchangeable. Quote Link to comment
datsunaholic Posted March 11, 2009 Report Share Posted March 11, 2009 No, you don't need an adapter plate for that but I would use the original bakelite spacer with that one. I had one on my '74, it worked, kinda. Then the fast idle screw fell out. Supposedly those are/were CA Smog legal, but only if the CARB tag is still on it. You have the air filter adapter so it's generally good to go there. Quote Link to comment
72 CnC_WaGon Posted March 12, 2009 Author Report Share Posted March 12, 2009 thanks for the help you guys Quote Link to comment
