first thing you need to do before another single thing is fix the vacuum leak. then, put a small amount of oil in each cylinder. then do a compression test. twice on each cylinder to verify accuracy. then record the results. make sure the motor is warmed up when you do the test. you need to hold the throttle to the floor as you spin the motor to ensure the motor is producing accurate compression. also, don't forget to unhook your coil wire before you start the compression test. it will either end in a fire-y mess or the motor will start running. while you have the plugs out, grab a few pics and post them here. there are plenty of people here with insight if you send us a few pics. plugs can tell you a lot about how a motor is running. keep track of which plugs came out of which cylinder, it will help you identify which cylinder or isn't firing. check the oil in the motor. what's it look like? if it looks like chocolate milk, you probably have a headgasket gone bad. your valves & rockers are supposed to have slack between them. It probably could use a tune up, but its not for an amateur, take it to someone who KNOWS how to set valve lash. I happen to have access to 2 ASE certified mechanics of 20+ years when i need help or insight, (dad and grand dad) but we are not all so lucky.
