Just ordered new brake cylinders. I got this car over ten years ago and only drove it briefly before parking it. got it running again recently and only drove it around the block a few times before I started replacing parts (coil overs, control arms, tc rods etc.) figured I’d do the brakes while I was at it. So I’m not sure if the rear breaks ever worked properly. I did not bleed after I replaced the front, pumped the breaks a few times to build pressure back up while I was rolling out the drive way (yes I forgot to do this before putting it in gear) and then the rear driver side break locked up. Pounded off the drum and messed with it got the car to roll, jacked it up and put it in gear and found out neither wheel stopped when putting on the breaks. Tried bleeding and messing with the shoes a bit and the left locks up hard while the right doesn’t engage at all…. Long way to say that I’m not sure when the breaks went to shit.
