tdaaj Posted February 26, 2009 Report Share Posted February 26, 2009 so i attemped to pull the transmission out today.:mad::fu::mad: has anybody else out there tried to just pull the trans only on a j13 equipped truck? apparently i'm going to have to pull the engine too. there's no radiator in the truck. i've got the transmission suspended in the air with the engine up against the core support the the pilot shaft is still hanging up. i can't slide the trans back any farther either. is there something i'm missing? Quote Link to comment
crabbyone Posted February 26, 2009 Report Share Posted February 26, 2009 Did you pull the trans mount bracket off the crossmember? And the shift lever? And the trans mount itself? For such a small package, it can be a pain. Still easier to pull both as a unit. crabby Quote Link to comment
tdaaj Posted February 26, 2009 Author Report Share Posted February 26, 2009 i did i did i did. very much a pain. i have a solution though. i'm cutting the core support off to save it also. so everything will come out the front. Quote Link to comment
