72nismo Posted January 31, 2009 Report Share Posted January 31, 2009 I need to know if some 16x8" +13 SL disk 4x114.3 rims would fit on a 510 with stock fenders? Will it fit if fenders were rolled or they just wont fit? I need to asap. Thanks Quote Link to comment
WagDatto Posted February 1, 2009 Report Share Posted February 1, 2009 You'll need to do at LEAST roll, probably a larger-than-small pull as well to make them fit. It does depend on how low you go, too, and how much camber you're willing to run (front and rear). (Correcting what I've previously said) I'm running 15x7 -12 which pretty much (for the sake of argument) equals out to 15x7.5 +0 as far as how far it sticks out. 16x8 +13 is about the same (16x7.5 +0), however, 16's are a larger profile wheel, will cause problems with tire clearance (depending on sidewall and stretch). Basically, yes... You can make it work with a roll/pull and semi-stretched tires, depending on camber and ride height. Quote Link to comment
72nismo Posted February 1, 2009 Author Report Share Posted February 1, 2009 Anybody have any pics of a 510 with a roll and pull fender? Really curious to see what that looks like.:D Quote Link to comment
