Roman Tasel Posted January 22, 2009 Report Share Posted January 22, 2009 My truck not only idles rough, but also when i drove down the street, it dies. So I got out of my truck and checked my carburetor. The float was really low:o Its not the carburetor because ever since I bought the truck it did this before and after the carb was rebuilt. Are my fuel lines clogged? I have also heard that if you drill a small hole in your gas cap it vents your gas tank and yout car idles smoother!!???:blink::mellow::eek::P Quote Link to comment
racerx Posted January 22, 2009 Report Share Posted January 22, 2009 Isn't the float setting should be 1/2 way...check your manual for adjustment. What about the fuel filter, that can be clogged. Maybe you put in some cheap gas or accidently put diesel fuel... Quote Link to comment
