Guest DatsuNoob Posted January 8, 2009 Report Share Posted January 8, 2009 Do all stock KA24de's use the same fuel injectors? Are ones from 240sx and Frontiers the same size? Thanks. Quote Link to comment
Cuts metal like mad Posted January 8, 2009 Report Share Posted January 8, 2009 easy way to find out since you have both, pull them and compare the number stamped into the side. Quote Link to comment
Cuts metal like mad Posted January 8, 2009 Report Share Posted January 8, 2009 Oh, you might be able to read the number just by pulling off the keepers on top... Can't remember, been awhile. :D Quote Link to comment
Guest DatsuNoob Posted January 8, 2009 Report Share Posted January 8, 2009 :lol: Yeah, I was away from the garage at the time. I'll check later today, I was just curious at the time. The number on the side will be a part number, a number indicating size, or what? To compare, I tried to find specs on stock injectors on the web with no luck. Thanks for the washers too btw, motor's still where we put it (minus an intake mani). I think I'm gonna weld up those little smog ports today, didnt get to it yesterday. Quote Link to comment
