Stumpifyer Posted August 17 Report Share Posted August 17 Rebuilt a carb today for my '80 4x4 720. I can't find where this little brass plug goes, and the truck does not respond to idle adjustment srew anymore, I feel like it's running lean, and will bog down around mid gas pedal push. I have a camping trip Sunday and need to figure this out! 😠Quote Link to comment
Sephakrid Posted August 17 Report Share Posted August 17 Do you have a picture of the plug? Does it look like this? Â Quote Link to comment
datzenmike Posted August 17 Report Share Posted August 17 Listen near the rear of the carburetor and don't start, but turn ignition on off, on off. You should hear a soft clicking sound. This is the idle cut solenoid working. If not working there will be no fuel getting to the idle circuit. Won't idle below about 1,200 RPMs.See if the Red wire (idle cut solenoid) and the Blue wire automatic choke and connected. Â Â Quote Link to comment
