Thirdman Posted May 31 Report Share Posted May 31 I broke this part off. When changing out the thermostat, I found lots of gunk in there and was cleaning it out. I thought I would remove this to clean it out as well. It looked like it was just threaded in. It broke right off as soon as I tried to remove it. Can any one tell me what part this is? Also, any suggestions on removing the metal portion that was left behind in there? Quote Link to comment
Thirdman Posted May 31 Author Report Share Posted May 31 I was unable to post the image links into the post so I hope these links work. https://imgur.com/K6G98oK https://imgur.com/6PnDauV https://imgur.com/UOJ668l Quote Link to comment
datzenmike Posted May 31 Report Share Posted May 31 Thermal Vacuum Valve is my guess. When cold it blocks vacuum from passing through it. Once the engine warms it opens and lets vacuum through, probably to the EGR valve. It's broken so not working anyway. You do not want to remove the remains as it goes into the cooling system and you'll have a leak. Presumably it will just stay the way it is. Look in the thermostat hole and you should see the other end. Quote Link to comment
Thirdman Posted May 31 Author Report Share Posted May 31 Thank you datzenmike for identifying that part for me. That part is still available for purchase. Are you saying it would not be advisable to remove the broken piece (it looks like it is threaded in) and replace it with a new one? I'd like to replace it if I can. Quote Link to comment
datzenmike Posted May 31 Report Share Posted May 31 Not at all saying that. Most delete or disable the EGR. You would need to remove the threads that are caught in the head. Or are there threads left? looks clean. You would need to drill out the brass part and use a large easy out. I would heat around the opening as aluminum expands twice as much as steel. When hot, spray down with WD-40 to suddenly cool and shock it several times then heat and try the easy out. Quote Link to comment
Z23T Posted June 4 Report Share Posted June 4 I wouldn't try to remove that ported vacuum switch if it's not being used, and it doesn't like it's in use since one of the barbs is snapped off and I don't see any vacuum hoses going to it. Trying to remove the old one could be a huge pain in the ass, and it doesn't look like its been leaking coolant at all. Save the money you would spend on a new switch and buy a battery hold down kit to replace that tarp strap holding your battery down. You don't want a battery flying around in the engine compartment when that tarp strap breaks. https://www.amazon.ca/xbrtaia-battery-Aluminum-holder-Battery/dp/B0CTFDJPHH/ref=sr_1_9?crid=3MPRQIZY01BUR&dib=eyJ2IjoiMSJ9.972FVe_ivD7TkhQiwtKgdSurOCPFD0hfFioYaRxiMCTB1guna-JqzvdwkSYht3EFbH-Ssv0g7XY-sKwdsRQqaNn29rrBJEjgznO9ym3hAV3Ek-nl9HmcFZ1H7aFsyhWNGeCvgwxet_y2vBl6dXmygD42LmZtDANJmXqblTjpPXPDOqYAcCN4sSwTbKNmBFlY5mlbt_rv_WVq4o1DZbCBhALOmB-uR2OypmUxu4r1DQgEyoegq_2bE5Y3V5nUr1T44zG7aAtXV9yPbIlQV0L4DFRzrGL5cSQSpUFLMZtN2TY.CuTsemvdkb136OqwR1X-GbBd_mIpOz2WBsSu7zOSihk&dib_tag=se&keywords=battery%2Bhold%2Bdown&qid=1717468039&sprefix=battery%2Bhold%2Caps%2C173&sr=8-9&th=1 Quote Link to comment
nathan.is.an.idiot12312 Posted June 7 Report Share Posted June 7 wouldnt worry about it these cars will pass all smog emissions without the egr equipment on at least in the states Quote Link to comment
