Anyone know what these connectors are for? ('86 720 5 speed)
Hello, first time writer having recently acquired a 1986 720 King cab in manual.
There's some jank with the wiring harness and I spent some time just familiarizing myself with the electrical components under the hood so I can correct them.
There were missing connections; most of which I realize are smog deletes and that's fine, but I am left with a few un finished connections that the wiring diagram doesn't appear to list, and that I can't find out about in my research or deduction.
I've attached images here. Thanks.
  • Replies 5
Those all appear to be connectors for the stock carb, which I assume was swapped with a Weber. The blue connector is likely for the altitude control relay and the second pic is the temp sensor for the carb (there is a second temp sensor for your gauge). Not sure on the other two wires but almost certainly stock carb related, since they're hanging loose in my truck too.
  • Thanks 1
