Sephakrid Posted March 8 Report Share Posted March 8 Just finished the test fit on a rear window. So far so good. Of course I won't know for sure until I get down to the glass shop for installation. I also noticed that the seal is made in the U.S. according to the label. 1 Quote Link to comment
Joecar Posted March 19 Report Share Posted March 19 On 3/7/2024 at 8:13 PM, Sephakrid said: Just finished the test fit on a rear window. So far so good. Of course I won't know for sure until I get down to the glass shop for installation. I also noticed that the seal is made in the U.S. according to the label. How did it go? I’m also looking to get the same one too. Do you have the link to the same seal by chance? Quote Link to comment
Sephakrid Posted March 20 Report Share Posted March 20 I haven't had a chance to get it installed yet. I'm currently reassembling and testing the cooling system (water pump, radiator, thermostat, various hoses). Once that's done I can hopefully get down to the shop! This is the page I ordered from: https://www.steelerubber.com/rear-window-gasket-70-4830-81 The seal was in stock last month, but in my infinite wisdom I shared it with some of the 720 Facebook groups and now it's back-ordered. Quote Link to comment
Joecar Posted April 8 Report Share Posted April 8 Any update on how well it sealed on the cab? I’m ready to order most of the glass seals on mine cause they are just destroyed Quote Link to comment
Sephakrid Posted April 11 Report Share Posted April 11 Nope not yet! My cooling system finally isn't leaking anymore, though. Progress! Quote Link to comment
Sephakrid Posted May 15 Report Share Posted May 15 I finally had the rear glass seal installed, along with a new slider. The shop said it was very tight, especially in the lower corners. I'm not sure if this is due to the seal or the slider, which is aftermarket CRL and may have been slightly too large. It went in eventually, though! Also, yes this truck is a heap and I question why I keep throwing money at it! 1 Quote Link to comment
Joecar Posted May 21 Report Share Posted May 21 On 5/14/2024 at 9:06 PM, Sephakrid said: I finally had the rear glass seal installed, along with a new slider. The shop said it was very tight, especially in the lower corners. I'm not sure if this is due to the seal or the slider, which is aftermarket CRL and may have been slightly too large. It went in eventually, though! Also, yes this truck is a heap and I question why I keep throwing money at it! Does it keep any water out? Also my rear window looks different from yours so I’m not sure if it will fit the same. My slider is different and the corners of mine are sharp angles Quote Link to comment
powderfinger Posted May 22 Author Report Share Posted May 22 (edited) 20 hours ago, Joecar said: My slider is different and the corners of mine are sharp angles Your window looks like the factory sliding glass window so a replacement seal should work fine. The one I purchased for mine worked well. I believe the link is in the beginning of this thread somewhere. Edit: it was in the first post of mine https://vintagerubber.com/datsun-720-pick-up-rear-glass-seal-cal-style-extended-king-cab-1980-1986/ Edited May 22 by powderfinger 1 Quote Link to comment
Sephakrid Posted May 22 Report Share Posted May 22 The dimensions on my original sliding window, measuring from the outer corners of the aluminum frame were: 50.5" bottom length 13.5" height, measuring from the middle 4' from bottom left to top right corner The aftermarket replacement window was about 0.5-1.0" longer in all dimensions and still worked with the seal. It just took the glass shop some extra time to get installed. I live in San Diego, so we don't get much rain, but I don't see any gaps between the seal and truck body. The bottom corners (see previous post) aren't perfect, but I suspect this may be related to the slightly different dimensions on the replacement window. Honestly, I like the look of the Vintage Rubber seal more, but it's been out of stock forever! 1 Quote Link to comment
Joecar Posted May 22 Report Share Posted May 22 2 hours ago, powderfinger said: Your window looks like the factory sliding glass window so a replacement seal should work fine. The one I purchased for mine worked well. I believe the link is in the beginning of this thread somewhere. Edit: it was in the first post of mine https://vintagerubber.com/datsun-720-pick-up-rear-glass-seal-cal-style-extended-king-cab-1980-1986/ So the one I have is without the groove in the rubber? Quote Link to comment
