Thomas Perkins Posted December 2, 2021 Report Share Posted December 2, 2021 (edited) Hey Ya'll,not long ago I replaced my inner and outer door weatherstrips.This is where I got it from.As you know you can't see the inside of the door panels,but the old weather strips are old and leak,which will cause parts on the inside to rust and rot.. They are a little long and I used my dremel tool to cut down. I also bought the new orange Nissan Door clips,these are the new style Nissan has,they are way better.If your window rattles when it is down,this will fix it.https://www.ebay.com/itm/133751626037 and here are the clips.The leak did damage the inside of the door panel a little,I did repair so the clips would hold the panel on..Nissan sells these but are are very high.https://www.ebay.com/itm/262724557931 You will need two sets of these clips,one for each door.I got my plastic panel remover from Harbor freight.https://www.harborfreight.com/trim-and-molding-tool-set-5-pc-64126.html Edited December 2, 2021 by Thomas Perkins 1 Quote Link to comment
