dougfj62 Posted August 31, 2021 Report Share Posted August 31, 2021 10 weekends of removing 50 years of oil, grease, dirt ,surface rust and metal corrosion from what seems to be a previous battery explosion. I finally finished the engine bay paint. Sprayed 4 coats of Primer Sealer. Sanded each primer coat with 220, 320 and 500 grit. Then did a final wet sanding with 600 grit. Sprayed 4 coats of Kasumi Green- Color code 554 5 Quote Link to comment
