The tale of a right front fender....
Bandit240
Ok, ive had 3 620 trucks in the last 5 years. They have all had the same right front fender. I got the fender in 2003 on my '79, then it got stuck on my '76 when the bondo fell off its fender in 2004 and then in 2005 when i got my '78, the old man had hit a gaurdrail so it needed a RFF. That fender has about 10 coats of paint on it.
'79, note that little dent in front of the light.
'76, theres the dent.
'78, still there.
If i ever get another 620, even if its RFF is ok, i will put that one on there.
  • Replies 5
Hahaha, that's awesome. :D If it were me I'd keep a little list on the inside of the fender, saying all the trucks I ever had it on. Are you ever going to strip it down to bare metal, or are you just going to keep adding topcoats? I take it the Datsun emblem and light haven't changed either.
I have swapped the emblem out. The light is the same one thats been on it the whole time.
It needs some decent work to smooth it out. When i first got it, it looks like someone did body work with a 4'' grinder on it. Right now it needs a new coat of blue, the yellow is starting to show on top.
