Datsun B110 Driftcar
Ratsun510
  • Replies 4
15 minutes ago, dukerollo said:
Cool!  The 5 cylinder fits in that engine bay? What are you going to run for a transmission?
Actually. No.
I take the Whole Front End out of a Volvo 850R Wagon. Cut out everything from behind the front seats on the Datsun and all luggage room.
Roll the Volvo Front end under and bolt it up. So in a way. it will be a FWD driven Machine frome volvo, mounted in the backseats, to make it RWD.
Quite simple really. You just take the Engine, complete with gearbox, beaks, suspension and everything From the Volvo, and bolt it up in the rear.
41914369_275716049941036_864978902807199
7 hours ago, dukerollo said:
So it is mid engine then, neat. I used to be a Volvo technician and messed around with them quite a bit. Those white blocks can be pretty potent. Post up some more pics.
Can't afford a Ferrari, so gotta build one myself!  400hp is my Goal for this summer. = 500whp/ton. If I had money I could almost make 1000hp/ton. But not until sponsored.
800kg and 400hp are more than enough!
