sunny310 Posted November 6, 2018 Report Share Posted November 6, 2018 Found these wheels on Summit.com n was wondering if these will fit my 210 or if they would be a bit too wide. They’re Aero 30 wheels 13x7 with -12.7 offset. Link below... https://www.summitracing.com/search/brand/aero-race-wheels/part-type/wheels/wheel-diameter/13-in/wheel-bolt-pattern-app/4-x-114-3mm/wheel-width-in/7-000-in/offset/minus-12-70mm Also found some used z31 4 lug wheels on eBay for about the same price as 4 of these Aeros...they do have some curb rash but not too bad...link below https://www.ebay.com/itm/84-89-300zx-Z31-OEM-15-wheels-rims-set-STOCK-factory-40300-03P00-1/192221347719?epid=1723001610&hash=item2cc148ff87:g:cokAAOSwo4VbczeM Quote Link to comment
dukerollo Posted November 8, 2018 Report Share Posted November 8, 2018 If you aren’t afraid of rolling/pulling your fenders they should fit fine. They should fit about like these, they had about 1/4” poke. Quote Link to comment
sunny310 Posted November 10, 2018 Author Report Share Posted November 10, 2018 On 11/8/2018 at 5:16 PM, dukerollo said: If you aren’t afraid of rolling/pulling your fenders they should fit fine. They should fit about like these, they had about 1/4” poke. Are those fenders rolled? Quote Link to comment
dukerollo Posted November 10, 2018 Report Share Posted November 10, 2018 Not in that pic. They are now. I have an Eastwood fender roller and had to be pretty aggressive. I'm not running any real stretch in my tires though. Quote Link to comment
sunny310 Posted November 16, 2018 Author Report Share Posted November 16, 2018 On November 9, 2018 at 10:42 PM, dukerollo said: Not in that pic. They are now. I have an Eastwood fender roller and had to be pretty aggressive. I'm not running any real stretch in my tires though. What size tires u running? Quote Link to comment
dukerollo Posted November 18, 2018 Report Share Posted November 18, 2018 They are 205/50-15. I could probably squeeze 225/45 in there if I really tried. I know now they are 15s and you are talking about 13s, but a 0 offset 15x8 should poke out about the same as a 13x7 -12. Quote Link to comment
sunny310 Posted November 23, 2018 Author Report Share Posted November 23, 2018 Thinking about getting these instead. 15x8 +20 offset. https://www.ebay.com/itm/MST-MT-13-15x8-4x100-114-3-20-SILVER-MESH-MACHINE-LIP-W-RIVET-TUNER-WHEELS-SET/322418872642?hash=item4b11a99142:g:PCoAAOSwcrZb5igB Quote Link to comment
dukerollo Posted November 24, 2018 Report Share Posted November 24, 2018 Don't know what you are running for front suspension but my 15x8 et0s are pretty close to the strut with 280zx suspension. It might be worth looking into those clearances before pulling the triggger. Quote Link to comment
sunny310 Posted November 24, 2018 Author Report Share Posted November 24, 2018 Front suspension is stock. Found the same wheel but 15x7 and +20. Will that fit? Quote Link to comment
dukerollo Posted November 25, 2018 Report Share Posted November 25, 2018 I don’t have a stock strut to measure. Maybe someone will chime in. Or, there used to be a website called willitfit.com. That may be helpful. Quote Link to comment
datb210sun Posted December 27, 2018 Report Share Posted December 27, 2018 wanted them for my b210, but wasn't so sure on the fitment as well. since, i'm converting to 280zx struts. i should be able to now.. Quote Link to comment
