Bugeye Posted November 2, 2008 Report Share Posted November 2, 2008 Both of the carb spacers for my l20 are warped pretty bad, bad enough when i lay them flat you can see it, does anybody have a couple they can spare? this is causing a huge vacuum leak and I cant get my truck to idle and its starting to piss me off Link to comment
twindragon6 Posted September 21, 2009 Report Share Posted September 21, 2009 (edited) I too have the same problem and am also looking for a spacer that will work... The bolt pattern is not the same as a Rochester or Holley. The Rochester is close but several mm off at the holes. These gaskets will seal with it (from Kragen). http://shop.oreillyauto.com/ProductDetail.aspx?MfrCode=VIC&MfrPartNumber=G31154 I will try to find a part number from Nissan. Edited September 21, 2009 by twindragon6 Improper information Link to comment
datsunaholic Posted September 21, 2009 Report Share Posted September 21, 2009 Geez, I just bought a couple at the dealer. Don't have the part number offhand, but they come with the gaskets pre-glued on. Link to comment
twindragon6 Posted September 25, 2009 Report Share Posted September 25, 2009 (edited) Here is the Nissan part number 16174-o5wo2. also 80306 on the package not sure if that's relevant. It's called a "Carburetor Insulator". Also if you plan on making your own gasket I'd go with some premium Fel-Pro rubberized fiber sheet or rubberized cellulose and try and keep it neat. Don't rush making one or it wont fit right and will leak. :cool: Edited September 25, 2009 by twindragon6 Link to comment
