abusaidi Posted October 24, 2008 Report Share Posted October 24, 2008 I have placed the drivetrain into my 1968 1600 Roadster and wired it more or less according to this info: http://forum.ratsun.net/showthread.php?t=549 But i am having a couple of issues. 1) the fuel relay does not seem to be to ground. ie, the black/pink does not compete the circuit causing the fuel pump to have power , the harness is grounded. All the other relays work as advertised. 2) I am not sure if this is related to point 1, but I have no juice at the coil. Thoughts? Thanks in advance. ~Robert Quote Link to comment
abusaidi Posted October 25, 2008 Author Report Share Posted October 25, 2008 more info. I have spark, as a can of Starter Fluid proved. Now the question is what is the minimum required to get the fuel injection going? Cheers, ~Robert Quote Link to comment
nismopu Posted October 25, 2008 Report Share Posted October 25, 2008 With the key in the on postion, make not of your dizzy's location. Then pull it out and rotate the gear in your hand, listen to hear if your injectors are firing. I am willing to bet they are but side feeds are notorious for going out on nissans. So, check them one by one; just unplug and plug each one. Quote Link to comment
