pipefitter Posted November 14, 2015 Author Report Share Posted November 14, 2015 2 Quote Link to comment
pipefitter Posted November 14, 2015 Author Report Share Posted November 14, 2015 So I buffed up the valve cover and got the fan on. 1 Quote Link to comment
mcordero8 Posted November 17, 2015 Report Share Posted November 17, 2015 Looks awesome! Where did you get your red wires? Quote Link to comment
pipefitter Posted November 17, 2015 Author Report Share Posted November 17, 2015 I ordered a set of universal v-8 wires that you have to make up one end,now I have a extra set when these need replacing Quote Link to comment
pipefitter Posted November 26, 2015 Author Report Share Posted November 26, 2015 So I get everything full and bolted up and while putting in the anti-freeze I notice some dripping out the bottom WTF I guess the guy I got the motor fom liked to tinker and pulled the water pump then bolted it back on with no silicone(my bad I should have replaced the water pump anyway I know better)so back apart it comes and then back together .I am pretty amped about now I want to see how this thing runs so I know if I got a good motor or got burned.anyway I pull the plugs and turn it over for about 30 seconds then again I keep this up until I have good oil coming out on the cam bolt t all back up and turn the key,its turning over but nothing I try again same thing I start thinking and oh ya I pulled the coil wire during this prcess so plug it back in and she starts before it even does a full wind.COOL at least it runs so I let it get warm and start checking timing is 13 degrees not bad so I roll it to 10,adjust the carb I only change the idle 1/4 turn and mixture 1/2 turn in wow that was the easiest start u I ever did, so I take for alittle ride sounds pretty good going through the gears may even have a small cam idles with alittle lump.well I shut it off and start checking eveything looks good but I see some oil and it is coming out of the timing cover F...K well everything has to come apart AGAIN! but this is fun right.anyway time to start the bed. 1 Quote Link to comment
pipefitter Posted November 26, 2015 Author Report Share Posted November 26, 2015 So I pull the bed off and pressure wash everthing good go at it with the putty knife and pressure wash again, ut it back inside and see if the the frame I fabed up will fit. Quote Link to comment
pipefitter Posted November 26, 2015 Author Report Share Posted November 26, 2015 1 Quote Link to comment
pipefitter Posted November 26, 2015 Author Report Share Posted November 26, 2015 I had to space the frame up with another piece of tube steel so I put a full length in front and another near the back and just used pieces in between then started the rear of the frame. 2 Quote Link to comment
