sdsurf Posted September 21, 2008 Report Share Posted September 21, 2008 L16 - I have a vacuum line off my carb and one off the intake manifold. Where do these go? One I know is to the vacuum advance on the the dist but which one? Also I have an extra line off the water neck (upper hose). where does this go? Quote Link to comment
SRSANDS Posted September 23, 2008 Report Share Posted September 23, 2008 Im not a engine guru but I recently got my L16 running pretty good buy doing the following.... The upper hole by the water inlet I capped The vacume connection at the base of the carb I ran the the advance on the dizzy and I capped the mani vac outlet..... May be right may not just putting on my two cents to get feed back also:D Quote Link to comment
