Datsun fan Posted September 18, 2008 Report Share Posted September 18, 2008 Hey every body ! I'm back !!! I have A15 A Nissan engine with 3N71B Auto gearbox the engine is well tuned, the performace was bad , and then , I took a look into the carb ( Hitachi I think ) and guess what !!!???? I found strange jets sizes and and more , they are as follows : the small air jet size is numberd 70 and is :"coupled" with gas jet size 101 the big air jet size is numberd 60 and is :"coupled" with gas jet size 130 Can you guys believe it ??? OK now ; I want to know the right sizes and combination , I'm looking for little economic and good perfomance setup , note that installed small and big air jets are not interchangable ! but gas jets are . Any suggestions and info are appreciated .............. Quote Link to comment
datsunfish Posted September 18, 2008 Report Share Posted September 18, 2008 You will never get performance out of that. Those are most likely the stock jets for that vehicle. A new carb would be your best bet for both economy and pep in my opinion. Quote Link to comment
racerx Posted September 19, 2008 Report Share Posted September 19, 2008 Those carbs are meant to pass smog and save gas...if you don't need to smog get a 32/36 weber. Don't even try to mess with the jets thinking that you will get "performance" because if you mess with one jet, you will more than likely have to mess with others. Quote Link to comment
