laotsu Posted August 27, 2014 Report Share Posted August 27, 2014 I am trying to install my newly built LZ into my 1972 521. it is a Z20s block and L16 motor mounts. I am haveing a FUCK of a time getting the engine onto the mount studs. should I be using L20B mounts? any Tricks to share? Quote Link to comment
uberkevin Posted August 27, 2014 Report Share Posted August 27, 2014 Try taking the mount off the block with the nut on the rubber/mount stud. Lift the block a little, the lower back down. Once you can see the hole put them bitch ass bolts in. I just did this. Hope they are 521 mounts. Also normally only need to do it on one side but I don't see why it wouldn't work doing both. Quote Link to comment
