worksnaDELUXE Posted June 13, 2014 Report Share Posted June 13, 2014 I'm throwing this SR set up in my 73 1200. I have some questions: What fuel pressure regulator/output do you suggest? What fuel pump/output do you suggest? Also I've searched and searched (maybe this isn't my strongest suit) but could find no SR20DE Carb build threads and limited info. I'm all over Datsun1200.com as well. So any links would help. Thanks! R Quote Link to comment
ggzilla Posted June 13, 2014 Report Share Posted June 13, 2014 OER carbs want 3.5 psi, so use a inexpensive fuel pump with no regulator Quote Link to comment
Nuclear Water Boy Posted June 17, 2014 Report Share Posted June 17, 2014 I'm throwing this SR set up in my 73 1200. I have some questions: What fuel pressure regulator/output do you suggest? What fuel pump/output do you suggest? Also I've searched and searched (maybe this isn't my strongest suit) but could find no SR20DE Carb build threads and limited info. I'm all over Datsun1200.com as well. So any links would help. Thanks! R Try The Realm here http://www.the510realm.com/viewtopic.php?f=27&t=10313 you'll have to go a few pages but this is a good write up on carbs on an SR. Lou Quote Link to comment
worksnaDELUXE Posted June 17, 2014 Author Report Share Posted June 17, 2014 Thanks Lou! :) Quote Link to comment
