magician Posted June 12, 2014 Report Share Posted June 12, 2014 I've taken out the intake while I was doin so water got into the inlet,I jacked the rhs and tried to get as much water out with a shammy.is it gonna cause me problems?wat should I do Quote Link to comment
MicroMachinery Posted June 12, 2014 Report Share Posted June 12, 2014 As long as there isn't enough to hydro lock your engine, it will just burn off into steam when you start your engine. To be sure you can remove your spark plugs and crank the engine over a few times; it should spit any excess out. Quote Link to comment
q-tip Posted June 12, 2014 Report Share Posted June 12, 2014 How much water we talking about? If you're really worried about it pull the spark plugs and turn the motor over, if it looks like a fountain there is a problem. Quote Link to comment
magician Posted June 13, 2014 Author Report Share Posted June 13, 2014 Thanks guys but seems that it wasn't too much water that got in,ur help was much appreciated! Quote Link to comment
