raser05 Posted May 26, 2014 Report Share Posted May 26, 2014 I am currently replacing l18 (1 and 2 low compression)with an l20b engine in my 74 620. It ran well in the 79 truck that it came out of 6 years ago. it has been sitting ever since then.. drained all the bad gas, blew the lines out and she fired right up.. ran a little ruff, I guess I expected that,, happy tho, It ran..my guess was the stock carb was the culprit as it was leaking gas from the front cover gasket.. so I ordered a rebuild kit from rock auto for 10 bucks just for the gasket, then I ordered a weber carb adapter just in case.I have a what I believe is an old 32/36 dveg forma vw bug.. (someone please tell me if this will work). anyway ...She started up ,no more leaks from the front cover, the only wire I hooked up out the the four coming from the 1979 stock carb was the electric choke..It ran pretty ruff. So off with the Hitachi and on with the weber. So I looked all over the net for a EGR block off plate. seen a lot for the KA's but none for the l series. So I awoke this morning without a plan for a cover and this is what I came up with.. first off I want to say that I am in no way a welder/fabricator or anything near. I do own a metal chop saw,grinder and a little wire feed welder. and this is my block off cover...cut from the original piece, filled the egr hole with weld.. ground down flat, went to lowes and grabbed 3/8 to 1/4 90 and the a cupler to fit the egr valve and BAM! block off plate completed for under 10 bucks.. Now I have to figure out what to do with the 3/4 copper like line coming from the back of the exhaust manifold.. Ideas? http://imageshack.com/a/img839/1983/ntbn.jpg http://imageshack.com/a/img834/9757/7k8c.jpg http://imageshack.com/a/img839/3449/1szw.jpg http://imageshack.com/a/img843/2666/q2brl.jpg http://imageshack.com/a/img839/2777/gkuz.jpg http://imageshack.com/a/img843/3006/qwm9.jpg Quote Link to comment
cj8281 Posted May 27, 2014 Report Share Posted May 27, 2014 Hmmm, on mine, I just tapped the two holes going into the intake with a 3/8 pipe tap then threaded in a 3/8 pipe plug with a little bit of puky on them. Quote Link to comment
datzenmike Posted May 27, 2014 Report Share Posted May 27, 2014 I don't know what I was expecting but that is the best one I have ever seen. Most just grind up some diamond plate and JB weld and I have to admit they all look like shit. 1 Quote Link to comment
