Dilligaf Posted May 19, 2014 Report Share Posted May 19, 2014 Would just like to know peoples opinions on acid dipping and sand blasting the chassis/cab Over in the states does any company stock/supply new rubbers (ill need everything and anything) Quote Link to comment
red13 Posted May 19, 2014 Report Share Posted May 19, 2014 I was able to get 90% of cab mounts from nissan. There are many different nissan oem sites. The one I used was http://www.nissanpartswarehouse.com/ All you have to do is have to part number. You can get that from Carpartsmanual.com I am sand blasting my frame and cab and using a grinder. Whatever it takes to clean. I got a 73 and its full of rust. Quote Link to comment
Dilligaf Posted May 20, 2014 Author Report Share Posted May 20, 2014 Awesome! Cheers for the info. ill probably soda blast the cab and sand blast the chassis. When i got the ball on the roll ill make a build thread. Quote Link to comment
JCalais Posted May 20, 2014 Report Share Posted May 20, 2014 Can get alot of rubbers/seals off of ebay. Quote Link to comment
Dilligaf Posted May 21, 2014 Author Report Share Posted May 21, 2014 Mainly after Cab - Chassis mount rubbers. Quote Link to comment
red13 Posted May 21, 2014 Report Share Posted May 21, 2014 I got my cab mounts from nissan. You can get most of them but the top four on the back end you can get from them. I found the center top ones at partsouq.com there in Dubai. So Ill mod the back ones probly from a hockey puck. Quote Link to comment
Dilligaf Posted May 22, 2014 Author Report Share Posted May 22, 2014 Cheers for the info Red. So its just the inside cab rubbers u cant get from nissan? Quote Link to comment
red13 Posted May 22, 2014 Report Share Posted May 22, 2014 yes, but like i did say partsouq.com you can get the forward inside ones there from Dubai. I try o do stock when i can I hate having to take extra time to make something work. Quote Link to comment
